Repair straightener ghd - Replace thermal fuse ghd
Video Overview
  1. Repair straightener ghd - Replace thermal fuse ghd, remove the round covers: step 1, image 1 of 2 Repair straightener ghd - Replace thermal fuse ghd, remove the round covers: step 1, image 2 of 2
    • Lightly lift the round covers using your finger to create a small opening.
    • Insert a thin flat screwdriver, or a lever if you have one in this opening.
    • Lift by trial and error to avoid breaking the teeth of these fragile covers. If they break, don't panic, you can glue them.
  2. Repair straightener ghd - Replace thermal fuse ghd, Remove the straightener axle screw: step 2, image 1 of 3 Repair straightener ghd - Replace thermal fuse ghd, Remove the straightener axle screw: step 2, image 2 of 3 Repair straightener ghd - Replace thermal fuse ghd, Remove the straightener axle screw: step 2, image 3 of 3
    • Sometimes these screws are mounted with screw glue. The best is to bring two screwdrivers, including a small one for better control.
    • Start by unscrewing the screw by having the first screwdriver fixed on one side, and the other unscrewing on the other side.
    • screw it out, push the shaft and take it out.
  3. Repair straightener ghd - Replace thermal fuse ghd, Remove the plastic pin and the spring.: step 3, image 1 of 2 Repair straightener ghd - Replace thermal fuse ghd, Remove the plastic pin and the spring.: step 3, image 2 of 2
    • Push the plastic axle with your screwdriver and take it out.
    • Remove the spring.
  4. Repair straightener ghd - Replace thermal fuse ghd, Unmount cache from branch and test: step 4, image 1 of 2 Repair straightener ghd - Replace thermal fuse ghd, Unmount cache from branch and test: step 4, image 2 of 2
    • Remove the two screws from the button side cover.
    • Remove the cover equipped with the button.
    • The electronic card is now accessible. You can test the thermal fuse if you wish.
  5. Repair straightener ghd - Replace thermal fuse ghd, Removal of the HS fuse: step 5, image 1 of 3 Repair straightener ghd - Replace thermal fuse ghd, Removal of the HS fuse: step 5, image 2 of 3 Repair straightener ghd - Replace thermal fuse ghd, Removal of the HS fuse: step 5, image 3 of 3
    • Unscrew the 4 screws that hold the plate to the electronic board.
    • The thermal fuse is now accessible.
    • To remove the HS fuse, slightly pull out its cables as shown in the photo.
    • Using small pliers, scissors or nail clippers, cut the two cables.
    • You can now easily pull out the fuse head and cables on the other side.
  6. Repair straightener ghd - Replace thermal fuse ghd, Reassembling the new thermal fuse: step 6, image 1 of 3 Repair straightener ghd - Replace thermal fuse ghd, Reassembling the new thermal fuse: step 6, image 2 of 3 Repair straightener ghd - Replace thermal fuse ghd, Reassembling the new thermal fuse: step 6, image 3 of 3
    • Insert the 2 cables of the new thermal fuse.
    • Lift the tab and insert the fuse head.
    • Pull the two cables and press on the head to firmly press the fuse against the ceramic plate.
  7. Repair straightener ghd - Replace thermal fuse ghd, Refit the plate and the cover.: step 7, image 1 of 3 Repair straightener ghd - Replace thermal fuse ghd, Refit the plate and the cover.: step 7, image 2 of 3 Repair straightener ghd - Replace thermal fuse ghd, Refit the plate and the cover.: step 7, image 3 of 3
    • Refit the plate on the electronic card using the 4 screws.
    • Do not forget to put the silicone part, which protects the electronic card against heat.
    • Refit the cover fitted with the button using the two screws.
  8. Repair straightener ghd - Replace thermal fuse ghd, Test run: step 8, image 1 of 1
    • Connect the straightener cable
    • You can now test the operation.
    • If you have a thermometer, the temperature should be between 180°C and 190°C. If you don't have one, turn on the straightener and let it heat up for 5 minutes to make sure everything is okay.
  9. Repair straightener ghd - Replace thermal fuse ghd, Final assembly: step 9, image 1 of 3 Repair straightener ghd - Replace thermal fuse ghd, Final assembly: step 9, image 2 of 3 Repair straightener ghd - Replace thermal fuse ghd, Final assembly: step 9, image 3 of 3
    • You can now reassemble everything:
    • First the spring, then the plastic axle, then the metal axle and finally the screws/washer and covers.
To reassemble your device, follow the steps in reverse order.
3 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Dr-lisseur.com
129 Reputation
1 Guide authored
One Comment
Bonjour j'ai un lisseur GHD le model est 4.2B , je l'ai brancher j'ai entendu 2 bip et plus rien , pensez-vous que c'est le fuisible qui est HS ? Cordialement
Laurent - Reply
Past 24 Hours: 18
Past 7 Days: 117
Past 30 Days: 454
All Time: 11,597
