HP 17-x061nr RAM Replacement
  1. HP 17-x061nr RAM Replacement, HP 17-x061nr  Disassembly: step 1, image 1 of 3 HP 17-x061nr RAM Replacement, HP 17-x061nr  Disassembly: step 1, image 2 of 3 HP 17-x061nr RAM Replacement, HP 17-x061nr  Disassembly: step 1, image 3 of 3
    • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
  2. HP 17-x061nr RAM Replacement: step 2, image 1 of 2 HP 17-x061nr RAM Replacement: step 2, image 2 of 2
    • Peel back the rubber footrests located next to the battery, on the left and right sides.
    • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
  3. HP 17-x061nr RAM Replacement: step 3, image 1 of 1
    • Slide the optical drive out and away from the laptop.
  4. HP 17-x061nr RAM Replacement: step 4, image 1 of 3 HP 17-x061nr RAM Replacement: step 4, image 2 of 3 HP 17-x061nr RAM Replacement: step 4, image 3 of 3
    • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
    • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
    • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
  5. HP 17-x061nr RAM Replacement, RAM: step 5, image 1 of 1
    • Locate the RAM module.
    • Locate the metal clips on either side of the RAM module.
  6. HP 17-x061nr RAM Replacement: step 6, image 1 of 1
    • Using your finger, pry the metal clip from both sides of the RAM module and the module will "pop" up.
  7. HP 17-x061nr RAM Replacement: step 7, image 1 of 1
    • Remove and replace the RAM module.
    • Be sure to keep the replacement within the package until you are ready to place it.
Amaury Ferrer
235 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 886
