RC Vehicle Electronic Speed Control Replacement
  1. RC Vehicle Electronic Speed Control Replacement, Electronic Speed Control: step 1, image 1 of 2 RC Vehicle Electronic Speed Control Replacement, Electronic Speed Control: step 1, image 2 of 2
    • Position the car so that the wires are facing upwards.
  2. RC Vehicle Electronic Speed Control Replacement: step 2, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 2, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 2, image 3 of 3
    • Unplug the blue wire.
    • Unplug the yellow wire.
    • To unplug these wires, firmly grasp the metal connector, then pull straight out.
    • Grab the wires by their metal connector, not the wire itself, to prevent any damage to the wires.
  3. RC Vehicle Electronic Speed Control Replacement: step 3, image 1 of 2 RC Vehicle Electronic Speed Control Replacement: step 3, image 2 of 2
    • Unplug the thin bundle of black, white, and red wires.
    • Move both ends to the side of the car to clear your workspace.
  4. RC Vehicle Electronic Speed Control Replacement: step 4, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 4, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 4, image 3 of 3
    Tool used on this step:
    iFixit Opening Tool
    $1.99
    Buy
    • Slide an opening tool beneath the red controller unit.
    • Pry upwards with moderate force until the controller unit is detached.
  5. RC Vehicle Electronic Speed Control Replacement: step 5, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 5, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 5, image 3 of 3
    iFixit Opening Tool
    $1.99
    Buy
    • Slide an opening tool beneath the power button.
    • Pry upwards with moderate force until the power button is detached.
  6. RC Vehicle Electronic Speed Control Replacement: step 6, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 6, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 6, image 3 of 3
    • Dampen a shop towel with 99.9% pure isopropyl alcohol.
    • Rub the dampened towel over any residual adhesive on the car.
    • Clean the residue until the surface is smooth.
    • Isopropyl alcohol is extremely flammable. Work away from heat sources to prevent serious fires.
  7. RC Vehicle Electronic Speed Control Replacement: step 7, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 7, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 7, image 3 of 3
    • From this step onwards, work with your new controller unit, not the old one.
    • Rub the dampened towel over the bottom of the controller unit.
  8. RC Vehicle Electronic Speed Control Replacement: step 8, image 1 of 1
  9. RC Vehicle Electronic Speed Control Replacement: step 9, image 1 of 2 RC Vehicle Electronic Speed Control Replacement: step 9, image 2 of 2
    • Position the controller unit so that the bottom faces upwards.
    • Unwind 1 inch of double-sided adhesive.
    • Center the adhesive on the bottom and press down to secure it.
  10. RC Vehicle Electronic Speed Control Replacement: step 10, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 10, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 10, image 3 of 3
    Utility Scissors
    $5.59
    Buy
    • Trim any excess adhesive from the bottom of the controller unit.
    • Smooth the adhesive by rubbing it with your thumb.
  11. RC Vehicle Electronic Speed Control Replacement: step 11, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 11, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 11, image 3 of 3
    • Repeat Steps 9 and 10 with the power button instead of the controller unit.
  12. RC Vehicle Electronic Speed Control Replacement: step 12, image 1 of 1
    • The bottom of your controller unit and power button should look like the given image.
  13. RC Vehicle Electronic Speed Control Replacement: step 13, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 13, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 13, image 3 of 3
    • Peel off the red layer from the adhesive attached to the controller unit.
    • Secure it to the original spot of the old controller unit.
    • Use a precision knife to easily remove the layer on your double-sided adhesive.
  14. RC Vehicle Electronic Speed Control Replacement: step 14, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 14, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 14, image 3 of 3
    • Peel off the red layer from the double-sided adhesive attached to the power button.
    • Secure it to the original spot of the old power button.
  15. RC Vehicle Electronic Speed Control Replacement: step 15, image 1 of 2 RC Vehicle Electronic Speed Control Replacement: step 15, image 2 of 2
    • Locate the thin bundle of black, white, and red wires and reconnect their heads.
  16. RC Vehicle Electronic Speed Control Replacement: step 16, image 1 of 2 RC Vehicle Electronic Speed Control Replacement: step 16, image 2 of 2
    • Secure the black, white, and red wires to the frame of your car using two 4-inch zip ties.
  17. RC Vehicle Electronic Speed Control Replacement: step 17, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 17, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 17, image 3 of 3
    • Plug the yellow wire into the connector at the bottom of the motor (Image 2).
    • Plug the blue wire into the connector at the top of the motor (Image 3).
  18. RC Vehicle Electronic Speed Control Replacement: step 18, image 1 of 3 RC Vehicle Electronic Speed Control Replacement: step 18, image 2 of 3 RC Vehicle Electronic Speed Control Replacement: step 18, image 3 of 3
    • Tuck away the thick red and black charging wires.
    • Securing the charging wires using Velcro is optional but recommended to keep the wires from moving while driving your vehicle.
Finish Line
Maxwell Limon
277 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 65
All Time: 1,113
