RCA 8 Apollo Screen Replacement
  1. RCA 8 Apollo Screen Replacement, Back Panel: step 1, image 1 of 1
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Screen Replacement: step 2, image 1 of 2 RCA 8 Apollo Screen Replacement: step 2, image 2 of 2
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Screen Replacement: step 3, image 1 of 2 RCA 8 Apollo Screen Replacement: step 3, image 2 of 2
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Screen Replacement, Display Assembly: step 4, image 1 of 3 RCA 8 Apollo Screen Replacement, Display Assembly: step 4, image 2 of 3 RCA 8 Apollo Screen Replacement, Display Assembly: step 4, image 3 of 3
    • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
    • Remove the yellow tape that is around the battery.
    • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
    • If the connector is misaligned, the pins can bend, causing permanent damage.
  5. RCA 8 Apollo Screen Replacement: step 5, image 1 of 1
    • Remove the three screws from the motherboard using a Phillips screwdriver.
  6. RCA 8 Apollo Screen Replacement: step 6, image 1 of 1
    • Remove the battery and motherboard together from the tablet.
    • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
    • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
  7. RCA 8 Apollo Screen Replacement, Screen: step 7, image 1 of 3 RCA 8 Apollo Screen Replacement, Screen: step 7, image 2 of 3 RCA 8 Apollo Screen Replacement, Screen: step 7, image 3 of 3
    • Remove the screw from the bottom left of the tablet.
    • Place an opening tool under the screen.
    • Pry up the screen and it will unclip from the clips holding the screen down.
    • Avoid using too much force to prevent the glass from breaking.
McKenna Shipper
123 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 10
All Time: 120
