RCA 8 Apollo Volume Button Replacement
  1. RCA 8 Apollo Volume Button Replacement, Back Panel: step 1, image 1 of 1
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Volume Button Replacement: step 2, image 1 of 2 RCA 8 Apollo Volume Button Replacement: step 2, image 2 of 2
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Volume Button Replacement: step 3, image 1 of 2 RCA 8 Apollo Volume Button Replacement: step 3, image 2 of 2
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Volume Button Replacement, Volume Button: step 4, image 1 of 1
    • The volume button control pad is located in the back panel, on the right side of the tablet.
    • Push on the outside of the volume button control pad and it will simply loosen and detach.
Brooke Still
123 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 81
