RCA CC310 Viewfinder Replacement
  1. RCA CC310 Viewfinder Replacement, Viewfinder: step 1, image 1 of 2 RCA CC310 Viewfinder Replacement, Viewfinder: step 1, image 2 of 2
    • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
    • Pushing the viewfinder assembly to the right makes lifting the flap easier.
    • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
  2. RCA CC310 Viewfinder Replacement: step 2, image 1 of 3 RCA CC310 Viewfinder Replacement: step 2, image 2 of 3 RCA CC310 Viewfinder Replacement: step 2, image 3 of 3
    • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable connects off of the viewfinder assembly.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Viewfinder Replacement: step 3, image 1 of 2 RCA CC310 Viewfinder Replacement: step 3, image 2 of 2
    • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up and remove.
  4. RCA CC310 Viewfinder Replacement: step 4, image 1 of 1
    • Flip back the viewfinder access tab.
    • Unscrew the 7.0mm ph #0 screw next to the mirror.
  5. RCA CC310 Viewfinder Replacement: step 5, image 1 of 3 RCA CC310 Viewfinder Replacement: step 5, image 2 of 3 RCA CC310 Viewfinder Replacement: step 5, image 3 of 3
    • Lift off both sides of the plastic assembly.
    • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
  6. RCA CC310 Viewfinder Replacement: step 6, image 1 of 2 RCA CC310 Viewfinder Replacement: step 6, image 2 of 2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  7. RCA CC310 Viewfinder Replacement: step 7, image 1 of 3 RCA CC310 Viewfinder Replacement: step 7, image 2 of 3 RCA CC310 Viewfinder Replacement: step 7, image 3 of 3
    • Lift plastic housing and guide the wires from underneath.
    • Lift out the entire circuit board and viewfinder.
    • Replace entire circuit board and viewfinder assembly.
Oliver Adams
629 Reputation
6 Guides authored
Cal Poly, Team 5-20, Amido Winter 2011 Member of Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Members
7 Guides authored
1 Guide Comment
do you know where i can find a relacement one of these parts
Connor Byrley - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 2,620
