RCA Lyra X2400 Audio Jack Replacement
  1. RCA Lyra X2400 Audio Jack Replacement, Screen: step 1, image 1 of 2 RCA Lyra X2400 Audio Jack Replacement, Screen: step 1, image 2 of 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  2. RCA Lyra X2400 Audio Jack Replacement: step 2, image 1 of 2 RCA Lyra X2400 Audio Jack Replacement: step 2, image 2 of 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  3. RCA Lyra X2400 Audio Jack Replacement: step 3, image 1 of 3 RCA Lyra X2400 Audio Jack Replacement: step 3, image 2 of 3 RCA Lyra X2400 Audio Jack Replacement: step 3, image 3 of 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  4. RCA Lyra X2400 Audio Jack Replacement, Motherboard: step 4, image 1 of 2 RCA Lyra X2400 Audio Jack Replacement, Motherboard: step 4, image 2 of 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  5. RCA Lyra X2400 Audio Jack Replacement, Audio Jack: step 5, image 1 of 2 RCA Lyra X2400 Audio Jack Replacement, Audio Jack: step 5, image 2 of 2
    • Locate the audio jack on the Lyra X2400. If you have difficulty locating this component look at the picture to the left.
    • Start using the solder/desolder tools to remove this component.
    • Once removed replace the old audio jack with a new audio jack.
    • Use soldering tools to reattach this component back to the main logic board.
Joseph Goodwin
1 Reputation
5 Guides authored
Cal Poly, Team 17-3, Regan Spring 2013 Member of Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 229
