RCA RCR8622 Buttons Replacement
  1. RCA RCR8622 Buttons Replacement, Speaker: step 1, image 1 of 3 RCA RCR8622 Buttons Replacement, Speaker: step 1, image 2 of 3 RCA RCR8622 Buttons Replacement, Speaker: step 1, image 3 of 3
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
  2. RCA RCR8622 Buttons Replacement: step 2, image 1 of 3 RCA RCR8622 Buttons Replacement: step 2, image 2 of 3 RCA RCR8622 Buttons Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
  3. RCA RCR8622 Buttons Replacement: step 3, image 1 of 2 RCA RCR8622 Buttons Replacement: step 3, image 2 of 2
    • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
  4. RCA RCR8622 Buttons Replacement, LCD Screen: step 4, image 1 of 3 RCA RCR8622 Buttons Replacement, LCD Screen: step 4, image 2 of 3 RCA RCR8622 Buttons Replacement, LCD Screen: step 4, image 3 of 3
    • Remove the two 11mm screws from the motherboard with the Phillip's #1 screwdriver.
    • Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard.
  5. RCA RCR8622 Buttons Replacement: step 5, image 1 of 3 RCA RCR8622 Buttons Replacement: step 5, image 2 of 3 RCA RCR8622 Buttons Replacement: step 5, image 3 of 3
    • Lift the motherboard out of the interior of the device.
    • Remove the screen section of the device by lifting upward on the circuit it is connected to by sliding it upwards.
    • Both sections will be connected with a ribbon connection.
  6. RCA RCR8622 Buttons Replacement: step 6, image 1 of 3 RCA RCR8622 Buttons Replacement: step 6, image 2 of 3 RCA RCR8622 Buttons Replacement: step 6, image 3 of 3
    • Flip both components of the circuitry over and from the main motherboard you will see metal pins that lead to the LCD screen.
    • Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins.
  7. RCA RCR8622 Buttons Replacement: step 7, image 1 of 2 RCA RCR8622 Buttons Replacement: step 7, image 2 of 2
    • Lift the screen upward, taking care not to allow the films below it to fall out.
  8. RCA RCR8622 Buttons Replacement, Buttons: step 8, image 1 of 3 RCA RCR8622 Buttons Replacement, Buttons: step 8, image 2 of 3 RCA RCR8622 Buttons Replacement, Buttons: step 8, image 3 of 3
    • Identify which button needs to be changed out. There will be lables on the board indicating functionality of each button.
    • Flip the board over and find the button by the circles on the board.
    • Solder the 2 pins off the button and pinch the top of the button on the other side to pull off.
Josh Excell
449 Reputation
4 Guides authored
IUPUI, Team S6-G5, Baechle Spring 2018 Member of IUPUI, Team S6-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G5
3 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 418
