RCA RCR8622 Speaker Replacement
  1. RCA RCR8622 Speaker Replacement, Speaker: step 1, image 1 of 3 RCA RCR8622 Speaker Replacement, Speaker: step 1, image 2 of 3 RCA RCR8622 Speaker Replacement, Speaker: step 1, image 3 of 3
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
  2. RCA RCR8622 Speaker Replacement: step 2, image 1 of 3 RCA RCR8622 Speaker Replacement: step 2, image 2 of 3 RCA RCR8622 Speaker Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
  3. RCA RCR8622 Speaker Replacement: step 3, image 1 of 2 RCA RCR8622 Speaker Replacement: step 3, image 2 of 2
    • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
Josh Excell
449 Reputation
4 Guides authored
IUPUI, Team S6-G5, Baechle Spring 2018 Member of IUPUI, Team S6-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 333
