RCA RCT6077W2 Backplate Replacement
  1. RCA RCT6077W2 Backplate Replacement, Backplate: step 1, image 1 of 2 RCA RCT6077W2 Backplate Replacement, Backplate: step 1, image 2 of 2
    • Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
  2. RCA RCT6077W2 Backplate Replacement: step 2, image 1 of 2 RCA RCT6077W2 Backplate Replacement: step 2, image 2 of 2
    • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
    • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
3 other people completed this guide.
Ryan Williams
1,157 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 24
All Time: 1,362
