RCA RCT6272W23 Battery Replacement
  1. RCA RCT6272W23 Battery Replacement, Case: step 1, image 1 of 2 RCA RCT6272W23 Battery Replacement, Case: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Battery Replacement: step 2, image 1 of 2 RCA RCT6272W23 Battery Replacement: step 2, image 2 of 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Battery Replacement, Battery: step 3, image 1 of 1
    • Use a soldering iron to remove the soldered connections from the battery to the motherboard.
    • For your safety, and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Battery Replacement: step 4, image 1 of 1
    • Next, use the spudger to pry the battery off of the rest of the body.
    • The battery is taped on with double-sided tape. Prepare another strip of double-sided tape and have it ready to reattach the battery.
4 other people completed this guide.
Stephen Radachy
819 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 5,338
