RCA RCT6272W23 Rear Camera Replacement
  1. RCA RCT6272W23 Rear Camera Replacement, Case: step 1, image 1 of 2 RCA RCT6272W23 Rear Camera Replacement, Case: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Rear Camera Replacement: step 2, image 1 of 2 RCA RCT6272W23 Rear Camera Replacement: step 2, image 2 of 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Rear Camera Replacement, Motherboard: step 3, image 1 of 3 RCA RCT6272W23 Rear Camera Replacement, Motherboard: step 3, image 2 of 3 RCA RCT6272W23 Rear Camera Replacement, Motherboard: step 3, image 3 of 3
    • Use a soldering iron to remove the soldered connections on the motherboard
    • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Rear Camera Replacement: step 4, image 1 of 1
    • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
  5. RCA RCT6272W23 Rear Camera Replacement: step 5, image 1 of 2 RCA RCT6272W23 Rear Camera Replacement: step 5, image 2 of 2
    • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
  6. RCA RCT6272W23 Rear Camera Replacement: step 6, image 1 of 1
    • Pull up the motherboard from the rest of the body.
  7. RCA RCT6272W23 Rear Camera Replacement, Rear Camera: step 7, image 1 of 1
    • Using a spudger, gently pry off the camera from the back of the display
Stephen Radachy
819 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 344
