RCA RCT6272W23 Speaker Replacement
  1. RCA RCT6272W23 Speaker Replacement, Case: step 1, image 1 of 2 RCA RCT6272W23 Speaker Replacement, Case: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
  2. RCA RCT6272W23 Speaker Replacement: step 2, image 1 of 2 RCA RCT6272W23 Speaker Replacement: step 2, image 2 of 2
    • Press the plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover, so be careful when separating.
  3. RCA RCT6272W23 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove the soldered wire connections to the speaker.
    • Soldering irons can cause burns and severely damage your device. If in doubt, pause and think about it.
    • For more information about soldering, check out this guide.
  4. RCA RCT6272W23 Speaker Replacement: step 4, image 1 of 1
    • Pry the speaker gently out of its plastic enclosure using a spudger.
Stephen Radachy
819 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 390
