RCA RCT6378W2 Speaker Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. RCA RCT6378W2 Speaker Replacement, Speaker: step 1, image 1 of 3 RCA RCT6378W2 Speaker Replacement, Speaker: step 1, image 2 of 3 RCA RCT6378W2 Speaker Replacement, Speaker: step 1, image 3 of 3
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
  2. RCA RCT6378W2 Speaker Replacement: step 2, image 1 of 3 RCA RCT6378W2 Speaker Replacement: step 2, image 2 of 3 RCA RCT6378W2 Speaker Replacement: step 2, image 3 of 3
    • Remove back cover with plastic opening tool, exposing the battery and motherboard.
  3. RCA RCT6378W2 Speaker Replacement, Preparing the Wires: step 3, image 1 of 1
    • Uncoil the wires. If necessary, use a wire stripper to expose more of the wire.
  4. RCA RCT6378W2 Speaker Replacement, Soldering: step 4, image 1 of 2 RCA RCT6378W2 Speaker Replacement, Soldering: step 4, image 2 of 2
    • Solder the wires to the base of the speaker. The metal of the wire should be touching exposed metal on the speaker. Insure that the colors of the wires match the picture.
To reassemble your device, follow the instructions in steps 1 and 2 in reverse order.
Matthew Wills
468 Reputation
4 Guides authored
Clemson, Team 14-4, Shirley Spring 2015 Member of Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 337
