RCA RCT6773W22 Speaker Replacement
  1. RCA RCT6773W22 Speaker Replacement, Battery: step 1, image 1 of 2 RCA RCT6773W22 Speaker Replacement, Battery: step 1, image 2 of 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Speaker Replacement: step 2, image 1 of 3 RCA RCT6773W22 Speaker Replacement: step 2, image 2 of 3 RCA RCT6773W22 Speaker Replacement: step 2, image 3 of 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Speaker Replacement: step 3, image 1 of 3 RCA RCT6773W22 Speaker Replacement: step 3, image 2 of 3 RCA RCT6773W22 Speaker Replacement: step 3, image 3 of 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
  4. RCA RCT6773W22 Speaker Replacement, Speaker: step 4, image 1 of 3 RCA RCT6773W22 Speaker Replacement, Speaker: step 4, image 2 of 3 RCA RCT6773W22 Speaker Replacement, Speaker: step 4, image 3 of 3
    • Desolder the wire connected from the speaker to the motherboard.
    • Pry the speaker from the casing with a plastic opening tool.
Kelsea Weber
20,015 Reputation
32 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,902 Guides authored
One Comment
Where can I buy a replacement speaker?
laubd - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,101
