RCA Small Wonders Camcorder CC176 Viewfinder Replacement
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: step 1, image 1 of 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: step 1, image 2 of 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: step 1, image 3 of 3
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: step 2, image 1 of 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: step 2, image 2 of 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: step 2, image 3 of 3
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: step 3, image 1 of 2 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: step 3, image 2 of 2
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
Allison Baudoin
401 Reputation
4 Guides authored
James Madison, Team 2-1, Allen Fall 2011 Member of James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,305
