RCA ViSYS 25424RE1 Keypad Replacement
  1. RCA ViSYS 25424RE1 Keypad Replacement, Base: step 1, image 1 of 3 RCA ViSYS 25424RE1 Keypad Replacement, Base: step 1, image 2 of 3 RCA ViSYS 25424RE1 Keypad Replacement, Base: step 1, image 3 of 3
    • Remove the eight 11mm screws found on the bottom side of the base with a Phillips #00 screwdriver.
  2. RCA ViSYS 25424RE1 Keypad Replacement: step 2, image 1 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 2, image 2 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to separate the back and front pieces.
    • Gently remove the back cover, because the wires are connected to each piece.
  3. RCA ViSYS 25424RE1 Keypad Replacement: step 3, image 1 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 3, image 2 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 3, image 3 of 3
    • Unclip the wires that connect the front piece to the circuit board on the back piece.
  4. RCA ViSYS 25424RE1 Keypad Replacement, Keypad: step 4, image 1 of 2 RCA ViSYS 25424RE1 Keypad Replacement, Keypad: step 4, image 2 of 2
    • Remove the nine 11mm screws from the board using a Phillips #00 screwdriver, in order to expose the keyboard pressure sensors.
  5. RCA ViSYS 25424RE1 Keypad Replacement: step 5, image 1 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 5, image 2 of 3 RCA ViSYS 25424RE1 Keypad Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Lift the rubber keypad.
    • Use a pair of tweezers to lift the number pad from both ends at the same time.
Munija Ramin
143 Reputation
1 Guide authored
Penn State, Team 1-17, Kaschak Winter 2015 Member of Penn State, Team 1-17, Kaschak Winter 2015
PSU-KASCHAK-W15S1G17
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 303
