RICATECH-RTT22 Turntable Belt Replacement
  1. RICATECH-RTT22 Turntable Belt Replacement, Belt: step 1, image 1 of 3 RICATECH-RTT22 Turntable Belt Replacement, Belt: step 1, image 2 of 3 RICATECH-RTT22 Turntable Belt Replacement, Belt: step 1, image 3 of 3
    • Remove the arm holder by moving the needle to the side and lifting up.
    • Remove the rubber pad by lifting it up.
  2. RICATECH-RTT22 Turntable Belt Replacement: step 2, image 1 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 2, image 2 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 2, image 3 of 3
    • Flip over the record player. There should be screws (10mm phillips head) on the back.
    • Use your phillips head screwdriver to remove each screw (keep them in a safe place for later).
  3. RICATECH-RTT22 Turntable Belt Replacement: step 3, image 1 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 3, image 2 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 3, image 3 of 3
    • There will be three wires connecting the top to the bottom. Disconnect them carefully.
    • Put the back component of the record player to the side.
  4. RICATECH-RTT22 Turntable Belt Replacement: step 4, image 1 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 4, image 2 of 3 RICATECH-RTT22 Turntable Belt Replacement: step 4, image 3 of 3
    • Use your phillips head screwdriver to remove the three screws (8mm phillips head) holding the motor in place.
    • Keep in mind that there is some pressure on the motor, since the belt holds together the motor and turntable.
  5. RICATECH-RTT22 Turntable Belt Replacement: step 5, image 1 of 2 RICATECH-RTT22 Turntable Belt Replacement: step 5, image 2 of 2
    • Unbolt (6mm bolt) the turntable from the housing using your wrench.
    • Since the turntable is designed to rotate, make sure the other side of the pin is kept from rotating while unbolting.
  6. RICATECH-RTT22 Turntable Belt Replacement: step 6, image 1 of 2 RICATECH-RTT22 Turntable Belt Replacement: step 6, image 2 of 2
    • Carefully removed the rubber band from around the motor and extract the turntable from the device.
  7. RICATECH-RTT22 Turntable Belt Replacement: step 7, image 1 of 1
    • Remove the damaged belt. Place the new belt around the turntable.
  8. RICATECH-RTT22 Turntable Belt Replacement: step 8, image 1 of 2 RICATECH-RTT22 Turntable Belt Replacement: step 8, image 2 of 2
    • Follow the instructions backwards to reassemble the record player.
Finish Line
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 821
