RIDGID BELT SANDER R2740 Timing Belt Replacement
  1. RIDGID BELT SANDER R2740 Timing Belt Replacement, Timing Belt: step 1, image 1 of 1
    • Orientate the sander so that the timing belt housing is facing you.
    • Remove the 19mm T20 screw from the center of the timing belt housing.
  2. RIDGID BELT SANDER R2740 Timing Belt Replacement: step 2, image 1 of 1
    • Remove the timing belt housing.
  3. RIDGID BELT SANDER R2740 Timing Belt Replacement: step 3, image 1 of 1
    • Use your finger or a screwdriver to apply pressure on the belt away from the sander near one of the small wheels.
    • Rotate the large wheel while applying pressure until the timing belt is free from the wheels.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 994
