RIDGID Belt Sander R2740 On/Off Switch Replacement
  1. RIDGID Belt Sander R2740 On/Off Switch Replacement, Power Cord: step 1, image 1 of 2 RIDGID Belt Sander R2740 On/Off Switch Replacement, Power Cord: step 1, image 2 of 2
    • Orient the belt sander so that the RIDGID logo is facing you.
    • Remove the six 19 mm and three 51 mm T20 screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID Belt Sander R2740 On/Off Switch Replacement: step 2, image 1 of 2 RIDGID Belt Sander R2740 On/Off Switch Replacement: step 2, image 2 of 2
    • Remove the two 16 mm T10 screws.
    • Remove the support bracket that holds the power cord into place.
  3. RIDGID Belt Sander R2740 On/Off Switch Replacement: step 3, image 1 of 3 RIDGID Belt Sander R2740 On/Off Switch Replacement: step 3, image 2 of 3 RIDGID Belt Sander R2740 On/Off Switch Replacement: step 3, image 3 of 3
    • Lift the power cord from the resting grooves.
    • Rotate the switch so that the lock-on button is facing you.
    • Loosen the two 8 mm Phillips #3 screws.
    • Pull the two wires away from the switch.
  4. RIDGID Belt Sander R2740 On/Off Switch Replacement, On/Off Switch: step 4, image 1 of 1
    • Undo the two screws on the backside of the switch with a Phillips #3 screw driver.
  5. RIDGID Belt Sander R2740 On/Off Switch Replacement: step 5, image 1 of 1
    • Pull out the wires from the switch.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 834
