RIDGID Belt Sander R2740 Tension Lever Spring Replacement
  1. RIDGID Belt Sander R2740 Tension Lever Spring Replacement, Tension Lever Spring: step 1, image 1 of 1
    • Turn the belt sander so that the RIDGID logo is facing you.
    • Flip the tension lever to the open position so that the tension on the spring is released.
    • Remove any sandpaper that is on the belt sander.
  2. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: step 2, image 1 of 3 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: step 2, image 2 of 3 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: step 2, image 3 of 3
    • Using the T20 Torx Screwdriver, remove the two (2) M4 X 19 mm screws on either side of the the belt tension release lever.
    • Remove the side plate to reveal the spring.
  3. RIDGID Belt Sander R2740 Tension Lever Spring Replacement: step 3, image 1 of 2 RIDGID Belt Sander R2740 Tension Lever Spring Replacement: step 3, image 2 of 2
    • Remove and replace the spring (OD 14.47mm X 38.1mm).
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 24
All Time: 1,749
