RIDGID R32104 Motor Bearings Replacement
  1. RIDGID R32104 Motor Bearings Replacement, Motor Brush: step 1, image 1 of 2 RIDGID R32104 Motor Bearings Replacement, Motor Brush: step 1, image 2 of 2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Bearings Replacement: step 2, image 1 of 2 RIDGID R32104 Motor Bearings Replacement: step 2, image 2 of 2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Bearings Replacement: step 3, image 1 of 1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: step 4, image 1 of 3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: step 4, image 2 of 3 RIDGID R32104 Motor Bearings Replacement, Upper Blade Guard Assembly: step 4, image 3 of 3
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Bearings Replacement: step 5, image 1 of 2 RIDGID R32104 Motor Bearings Replacement: step 5, image 2 of 2
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Bearings Replacement: step 6, image 1 of 2 RIDGID R32104 Motor Bearings Replacement: step 6, image 2 of 2
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Bearings Replacement: step 7, image 1 of 2 RIDGID R32104 Motor Bearings Replacement: step 7, image 2 of 2
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: step 8, image 1 of 2 RIDGID R32104 Motor Bearings Replacement, Main Housing Assembly: step 8, image 2 of 2
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Bearings Replacement, Gear Box: step 9, image 1 of 2 RIDGID R32104 Motor Bearings Replacement, Gear Box: step 9, image 2 of 2
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Bearings Replacement, Motor Rotor: step 10, image 1 of 3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: step 10, image 2 of 3 RIDGID R32104 Motor Bearings Replacement, Motor Rotor: step 10, image 3 of 3
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
  11. RIDGID R32104 Motor Bearings Replacement, Motor Bearings: step 11, image 1 of 1
    • The bearings are located on the opposite end of the motor rotor, from where the fan blade was.
    • Carefully remove the motor bearings from the motor rotor.
2 other people completed this guide.
Lucas Pimentel
1,010 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 570
