Introduction
There are many issues that can be caused by a faulty motor brush. If you begin to hear banging sounds coming from the motor, this could be caused by the motor brush. Fortunately, a motor brush is one of the easiest parts to replace due to is accessibility. All you need is a standard flathead screwdriver to remove a cap.
Place down the Worm Drive Saw on a sturdy surface.
The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
