RIDGID R32104 Saw Blade Replacement
  1. RIDGID R32104 Saw Blade Replacement, Saw Blade: step 1, image 1 of 1
    • Turn off your saw and unplug before starting.
    • The RIDGID R32104 Saw did not come with a blade, so paper was used to mime the actions needed.
    • Place the Worm Drive Saw on a sturdy surface.
    • The blade is located within its upper blade guard and lower swing guard assembly.
  2. RIDGID R32104 Saw Blade Replacement: step 2, image 1 of 2 RIDGID R32104 Saw Blade Replacement: step 2, image 2 of 2
    • Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
    • In order to unscrew this, you must turn the screw clockwise to loosen it.
  3. RIDGID R32104 Saw Blade Replacement: step 3, image 1 of 1
    • Adjust the lower swing guard to properly grab the blade.
  4. RIDGID R32104 Saw Blade Replacement: step 4, image 1 of 1
    • Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
Lucas Pimentel
1,010 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 1,094
