RIDGID R84015 X2 Disassembly
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: step 1, image 1 of 2 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: step 1, image 2 of 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: step 2, image 1 of 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: step 3, image 1 of 2 RIDGID R84015 X2 Disassembly: step 3, image 2 of 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: step 4, image 1 of 1
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: step 5, image 1 of 1
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: step 6, image 1 of 1
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: step 7, image 1 of 1
    • Make sure plastic is not broken and switch is not stuck.
Finish Line
2 other people completed this guide.
Brian
100 Reputation
1 Guide authored
Cal Poly, Team 15-48, Garner Spring 2010 Member of Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Members
10 Guides authored
1 Guide Comment
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Reply Share
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 71
All Time: 14,124
