RIM BlackBerry 7510 Disassembly
  1. RIM BlackBerry 7510 Disassembly, RIM BlackBerry 7510: step 1, image 1 of 1
    • Remove the back cover exposing the battery, and remove the battery.
  2. RIM BlackBerry 7510 Disassembly: step 2, image 1 of 1
    • Remove the six screws with the screwdriver using the T-5 tip.
  3. RIM BlackBerry 7510 Disassembly: step 3, image 1 of 1
    • Pry open back cover
  4. RIM BlackBerry 7510 Disassembly: step 4, image 1 of 1
    • Lift off the back cover.
  5. RIM BlackBerry 7510 Disassembly: step 5, image 1 of 1
    • Unscrew the two screws with a T-6 screwdriver head
  6. RIM BlackBerry 7510 Disassembly: step 6, image 1 of 1
    • Remove chip
  7. RIM BlackBerry 7510 Disassembly: step 7, image 1 of 1
    • Unscrew to remove the back plate
  8. RIM BlackBerry 7510 Disassembly: step 8, image 1 of 1
    • Carefully pry off back plate
  9. RIM BlackBerry 7510 Disassembly: step 9, image 1 of 1
    • Take off front cover and keypad
  10. RIM BlackBerry 7510 Disassembly: step 10, image 1 of 1
    • Remove one screw in the front.
  11. RIM BlackBerry 7510 Disassembly: step 11, image 1 of 1
    • Pry the two parts apart.
  12. RIM BlackBerry 7510 Disassembly: step 12, image 1 of 1
    • The screen is now apart from the phone.
  13. RIM BlackBerry 7510 Disassembly: step 13, image 1 of 1
    • Using the Philips screwdriver unscrew center screw.
  14. RIM BlackBerry 7510 Disassembly: step 14, image 1 of 1
    • The final two parts now come apart.
  15. RIM BlackBerry 7510 Disassembly: step 15, image 1 of 1
    • The phone is now completely disassembled. Handle back with care shown piece comes right off.
  16. RIM BlackBerry 7510 Disassembly: step 16, image 1 of 1
    • Your blackberry has been fully disassembled.
Laura Yanez
2 Reputation
1 Guide authored
Cal Poly, Team 14-44, Regan Winter 2010 Member of Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 2,949
