ROYALAXE R68 TKL Key Switches Replacement
  1. ROYALAXE R68 TKL Key Switches Replacement, Key Switches: step 1, image 1 of 2 ROYALAXE R68 TKL Key Switches Replacement, Key Switches: step 1, image 2 of 2
    • Unplug the keyboard from its power source.
  2. ROYALAXE R68 TKL Key Switches Replacement: step 2, image 1 of 1
    • Remove all keycaps with the keycap puller.
    • You can line up the keycaps in order or take a picture of your keyboard to make it easier to put them back on at the end.
  3. ROYALAXE R68 TKL Key Switches Replacement: step 3, image 1 of 2 ROYALAXE R68 TKL Key Switches Replacement: step 3, image 2 of 2
    • Clean the keyboard using a compressed air duster and a small brush or cotton swab.
    • You can also clean your keycaps by soaking them in a bowl with water and soap for about 30 minutes.
  4. ROYALAXE R68 TKL Key Switches Replacement: step 4, image 1 of 2 ROYALAXE R68 TKL Key Switches Replacement: step 4, image 2 of 2
    • Remove the switches with the switch puller.
    • Make sure to clamp on the switch vertically instead of horizontally. Then gently pull it out.
    • Taking out the switch by pulling horizontally could damage the switch.
  5. ROYALAXE R68 TKL Key Switches Replacement: step 5, image 1 of 3 ROYALAXE R68 TKL Key Switches Replacement: step 5, image 2 of 3 ROYALAXE R68 TKL Key Switches Replacement: step 5, image 3 of 3
    • Make sure the copper part of the switch faces you when you try to insert the switch.
    • Insert the key switch as straight as possible and press down gently until you hear a click.
    • If you fail to line it up, it will bend the copper part under the switch. This will permanently damage the switch.
  6. ROYALAXE R68 TKL Key Switches Replacement: step 6, image 1 of 2 ROYALAXE R68 TKL Key Switches Replacement: step 6, image 2 of 2
    • Place keycaps in their respective position.
    • Make sure all keys are operating well.
    • Enjoy your new switches!
Finish Line
Angie
163 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 153
