RX 480 Disassembly, cleaning and thermal paste replacement
  1. RX 480 Disassembly, cleaning and thermal paste replacement, Large view of the RX480: step 1, image 1 of 1
    • This graphic card is really dirty, so this tutorial will show you how you can clean it and change the thermal paste
    • WARM UP THE CARD BEFORE THE TEARDOWN. IF THE CARD IS COLD THE THERMAL PADS MAY BREAK AND YOU WILL HAVE TO REPLACE THEM
    • Simply launch a game for a while or run a graphics benchmark to heat up the card.
  2. RX 480 Disassembly, cleaning and thermal paste replacement, Remove the fans: step 2, image 1 of 3 RX 480 Disassembly, cleaning and thermal paste replacement, Remove the fans: step 2, image 2 of 3 RX 480 Disassembly, cleaning and thermal paste replacement, Remove the fans: step 2, image 3 of 3
    • Standard philips screw
    • Once the screws are removed, simply pull the fan up, they have no cables.
  3. RX 480 Disassembly, cleaning and thermal paste replacement, Remove the backplate / front plate screws: step 3, image 1 of 2 RX 480 Disassembly, cleaning and thermal paste replacement, Remove the backplate / front plate screws: step 3, image 2 of 2
    • Standard Philips screw, be careful as they are not the same length.
  4. RX 480 Disassembly, cleaning and thermal paste replacement, Remove the plastic panel: step 4, image 1 of 1
    • Be very gentle, you don't want to break the fan power system. You can use your nails if you're not getting it out with a tool, some twist left/right make the job DO NOT PULL FROM THE CABLE ITSELF!
  5. RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: step 5, image 1 of 3 RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: step 5, image 2 of 3 RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: step 5, image 3 of 3
    • I personally clean the radiator using my vacuum cleaner, but you can just use a brush if you want.
  6. RX 480 Disassembly, cleaning and thermal paste replacement, Remove the radiator: step 6, image 1 of 2 RX 480 Disassembly, cleaning and thermal paste replacement, Remove the radiator: step 6, image 2 of 2
    • Standard philips screw.
    • The radiator can feel "glued" to the card, don't hesitate to use a bit of muscle to separate them.
  7. RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: step 7, image 1 of 3 RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: step 7, image 2 of 3 RX 480 Disassembly, cleaning and thermal paste replacement, Clean the radiator: step 7, image 3 of 3
    • Put some 70-90% alcohol, wait a bit for the thermal paste to get wet, then clean with a piece of makeup cotton, repeat until you get a proper result like in the third pic.
  8. RX 480 Disassembly, cleaning and thermal paste replacement, Clean the GPU: step 8, image 1 of 1
    • Clean with a Q-tip filled with alcohol
    • Put some alcohol on the gray chip, wait for the paste to get wet and clean with cotton.
    • Don't worry, alcohol is non conductible and will not damage your card.
  9. RX 480 Disassembly, cleaning and thermal paste replacement, Apply fresh thermal paste: step 9, image 1 of 1
    • Do not hesitate to apply a bit more than me.
  10. RX 480 Disassembly, cleaning and thermal paste replacement, All the components before remounting: step 10, image 1 of 1
    • You're done! Time to reassemble.
4 other people completed this guide.
Zeiko
274 Reputation
1 Guide authored
One Comment
Would have loved to see a reassebmly after. But still exelent guide! 👏👏
koki michev - Reply
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 98
All Time: 5,308
