RYOBI AG454 Driveshaft Replacement
  1. RYOBI AG454 Driveshaft Replacement, Carbon Brush: step 1, image 1 of 1
    • Remove the brush caps from each side of the body using the 4 mm flat head screwdriver.
  2. RYOBI AG454 Driveshaft Replacement: step 2, image 1 of 1
    • Remove the carbon brushes.
  3. RYOBI AG454 Driveshaft Replacement, Driveshaft: step 3, image 1 of 2 RYOBI AG454 Driveshaft Replacement, Driveshaft: step 3, image 2 of 2
    • Remove the two carbon brushes from both sides of the device.
  4. RYOBI AG454 Driveshaft Replacement: step 4, image 1 of 1
    • Remove the four 20mm screws that secures the gear box using a Phillips #1 screwdriver.
  5. RYOBI AG454 Driveshaft Replacement: step 5, image 1 of 1
    • Seperate the gear box case from body.
  6. RYOBI AG454 Driveshaft Replacement: step 6, image 1 of 1
    • Pull out drive shaft and remove it from the device.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 383
