RYOBI P422 Safety Trigger Spring Replacement
  1. RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: step 1, image 1 of 2 RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: step 1, image 2 of 2
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Safety Trigger Spring Replacement, Safety Trigger Spring: step 2, image 1 of 1
    • Lay grinder flat on its side so the screws are facing up
  3. RYOBI P422 Safety Trigger Spring Replacement: step 3, image 1 of 3 RYOBI P422 Safety Trigger Spring Replacement: step 3, image 2 of 3 RYOBI P422 Safety Trigger Spring Replacement: step 3, image 3 of 3
    • Remove the four 1.8 cm screws from the lower and midsection of the body with a T20-20 Torque screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver
  4. RYOBI P422 Safety Trigger Spring Replacement: step 4, image 1 of 3 RYOBI P422 Safety Trigger Spring Replacement: step 4, image 2 of 3 RYOBI P422 Safety Trigger Spring Replacement: step 4, image 3 of 3
    • Now that the two halves are unscrewed, remove the top half
  5. RYOBI P422 Safety Trigger Spring Replacement: step 5, image 1 of 3 RYOBI P422 Safety Trigger Spring Replacement: step 5, image 2 of 3 RYOBI P422 Safety Trigger Spring Replacement: step 5, image 3 of 3
    • Remove the safety trigger along with the spring.
    • To remove the spring, pull it gently off the bottom of the trigger.
    • When putting a new spring in make sure it slides into the grove on the bottom of the trigger.
Thomas Napert
279 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,735
