Radica Lighted Poker Case Lid Spring Replacement
  1. Radica Lighted Poker Case Lid Spring Replacement, Case Lid Spring: step 1, image 1 of 1
    • Turn over your Lighted Poker so the back is facing upwards.
  2. Radica Lighted Poker Case Lid Spring Replacement: step 2, image 1 of 3 Radica Lighted Poker Case Lid Spring Replacement: step 2, image 2 of 3 Radica Lighted Poker Case Lid Spring Replacement: step 2, image 3 of 3
    • Remove the six silver 6 mm screws with a Phillips #1 screwdriver.
    • Do not unscrew the centerpiece. It is for the batteries.
  3. Radica Lighted Poker Case Lid Spring Replacement: step 3, image 1 of 3 Radica Lighted Poker Case Lid Spring Replacement: step 3, image 2 of 3 Radica Lighted Poker Case Lid Spring Replacement: step 3, image 3 of 3
    • Open the device slowly without breaking or tearing the wires.
    • Remove the three black 7 mm self-sealing screws using a Phillips #00 screwdriver.
  4. Radica Lighted Poker Case Lid Spring Replacement: step 4, image 1 of 3 Radica Lighted Poker Case Lid Spring Replacement: step 4, image 2 of 3 Radica Lighted Poker Case Lid Spring Replacement: step 4, image 3 of 3
    • Gently remove both the button and hook piece.
    • Remove the damaged or old spring with a new 10 mm long and 8 mm to 3 mm radius spring.
    • Apply a small portion of grease lubricant on the button and hook piece to run smoother.
Diego Valdez
159 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 58
