Razer Barracuda X Battery Replacement
  1. Razer Barracuda X Battery Replacement, Battery: step 1, image 1 of 3 Razer Barracuda X Battery Replacement, Battery: step 1, image 2 of 3 Razer Barracuda X Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the cushion by pulling it off from the edge and out from the grooves.
    • Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Battery Replacement: step 2, image 1 of 1
    • Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
  3. Razer Barracuda X Battery Replacement: step 3, image 1 of 2 Razer Barracuda X Battery Replacement: step 3, image 2 of 2
    • Gently pull the speaker casing away from the shell.
    • Place it face down to access the battery.
  4. Razer Barracuda X Battery Replacement: step 4, image 1 of 2 Razer Barracuda X Battery Replacement: step 4, image 2 of 2
    • Unplug the battery from the socket.
    • Use a spudger to gently lift the battery up.
    • Remove the battery.
3 other people completed this guide.
Micah Ortiz
247 Reputation
2 Guides authored
UMass Dartmouth, Team 2-3, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G3
4 Members
7 Guides authored
7 Comments
What is the voltage of the battery?
Bavo Van Rillaer - Reply
It’s a 3.7V battery.
Dániel Baranyi -
Battery info Barracuda X Wireless (2022) version but I believe the non 2022 version also:
55345PN2 / 1ICP6/35/51 1200mAh/4.44Wh
Dominick -
Si, 3,7 v se ve muy mal en la foto del Paso 4
Carlos López (España - Spain) - Reply
How small is that battery?? i took mine apart and i saw i got the wrong size battery in general.
JPStruggle - Reply
Past 24 Hours: 8
Past 7 Days: 65
Past 30 Days: 274
All Time: 3,652
