Razer Basilisk V3 Backplate Replacement
  1. Razer Basilisk V3 Backplate Replacement, Skates: step 1, image 1 of 1
    • Locate the highlighted white skates on the bottom of the mouse.
  2. Razer Basilisk V3 Backplate Replacement: step 2, image 1 of 3 Razer Basilisk V3 Backplate Replacement: step 2, image 2 of 3 Razer Basilisk V3 Backplate Replacement: step 2, image 3 of 3
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Backplate Replacement, Backplate: step 3, image 1 of 1
    • Remove two 4.8 mm screws that were hidden under the front skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Backplate Replacement: step 4, image 1 of 3 Razer Basilisk V3 Backplate Replacement: step 4, image 2 of 3 Razer Basilisk V3 Backplate Replacement: step 4, image 3 of 3
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Backplate Replacement: step 5, image 1 of 3 Razer Basilisk V3 Backplate Replacement: step 5, image 2 of 3 Razer Basilisk V3 Backplate Replacement: step 5, image 3 of 3
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
Brendin Costa
402 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 61
Past 30 Days: 267
All Time: 3,157
