Razer BlackShark V2 Ear Cushion Replacement
Introduction
Go to step 1If your Razer BlackShark V2 foam ear cushions are shedding particles or detaching from the device (Razer Blackshark V2 Troubleshooting Page, "Ear Cushions Falling Apart"), this guide will assist you in their replacement. Be sure to be mindful of which layer of the headset assembly you're taking apart and that you don't adversely damage any holds, the rubber lining under the cushions, or the headset itself when applying pressure.
Scoop your middle and ring finger underneath the top or bottom inner portion of the ear cushion.
Pull from the hard plastic ridge, being sure not to pull from the soft cushion.
grab the inside with middle and ring finger from underneath the bottom inner portion of the ear cushion. and push with your thumb from the outside. (the clips face the oudside only scooping doesnt work great)
2 other people completed this guide.
2 Guide Comments
can someone pls tell me what's the size or mm of the foam?
