Introduction
The following guide will demonstrate how to open your Razer Blackwidow Tournament Edition Chroma. You will also learn how to remove and replace the USB port board.
Turn the keyboard over so that it is lying flat on its face.
Use the iFixit opening tool to pry the rubber feet off the keyboard.
Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
Use an opening tool as a wedge between the front and back panel to pry open the front panel.
Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
Flip the keyboard over so the keys are facing up.
Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
Use a Philips #1 Screwdriver to remove the four screws located below the keys.
Lift the main circuit board and flip it over, placing it on its top.
Pull on the wire connector until it disconnects from the USB port board.
One Comment
Where can I get another USB board? And it's possible to build one from scratch? I was thinking in upgrading to a USB C port
