Razer Blade 14" (2013) Battery Replacement
  1. Razer Blade 14" (2013) Battery Replacement, Remove the back cover: step 1, image 1 of 2 Razer Blade 14" (2013) Battery Replacement, Remove the back cover: step 1, image 2 of 2
    • Remove all 10 Torx T5 Screws
  2. Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: step 2, image 1 of 3 Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: step 2, image 2 of 3 Razer Blade 14" (2013) Battery Replacement, Disconnect the keyboard cables: step 2, image 3 of 3
    • Flip the hold down up
    • Remove the cable
    • Repeat for second cable
  3. Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: step 3, image 1 of 3 Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: step 3, image 2 of 3 Razer Blade 14" (2013) Battery Replacement, Remove Touchpad cable: step 3, image 3 of 3
    • Unclip hold-down
    • Remove cable
  4. Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: step 4, image 1 of 3 Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: step 4, image 2 of 3 Razer Blade 14" (2013) Battery Replacement, Disconnect Battery: step 4, image 3 of 3
    • Use a spudger to disconnect the plug from the connector by pulling it away from the socket, parallel to the board.
    • Bend the connector backwards to prevent it from getting in the way of the motherboard.
  5. Razer Blade 14" (2013) Battery Replacement, Remove Battery Screws: step 5, image 1 of 2 Razer Blade 14" (2013) Battery Replacement, Remove Battery Screws: step 5, image 2 of 2
    • Remove the 7 battery screws
  6. Razer Blade 14" (2013) Battery Replacement, Remove the Battery: step 6, image 1 of 2 Razer Blade 14" (2013) Battery Replacement, Remove the Battery: step 6, image 2 of 2
    • Remove the battery by pulling up from the side closest to the motherboard
    • Be careful of the other cables and the battery cable
    • You will have to lift up just a bit, then slide forward to clear one cable and the back cover screws
21 other people completed this guide.
tallme15
902 Reputation
2 Guides authored
17 Guide Comments
i want buy a battery for razer blade but I can't buy it anywhere
Please help me, my battery only 20% heathly
dinhphucloctmx - Reply
It seems that the only way to get the battery replaced is to send the laptop to Razer directly. According to others it costs about $200 plus shipping and so on. Unless you find something on eBay or that sort of thing.
tallme15 -
May I have a detailed guide on how you remove the cable over the battery, please? I am not used to taking machines apart, and wouldn't want to risk ruining my laptop. (didn't quite understand your pictures)
ceci - Reply
The only way to remove the cable is to work it out with a set of tweezers and be gentle not to pull the cables lose from the connector.
Samer Sultan -
Thank you for these instructions, it was very helpful, the only problem is now that the new battery has been installed, it will only charge to 73% and while its still plugged in the battery will drain down to 0%, is there a fix for this problem?
Jay - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 43
All Time: 28,653
