Razer Blade 15 (2022) Fan and Heatsink Replacement
  1. Razer Blade 15 (2022) Fan and Heatsink Replacement, Gather your tools: step 1, image 1 of 1
    • You will need
    • A torx and philips screwdriver
    • A dust blower and a brush
    • A spudger
    • An opening pick
    • A magnetic board
    • Microfibre cloth and alcohol
    • new thermal paste
  2. Razer Blade 15 (2022) Fan and Heatsink Replacement, Remove the laptop back cover: step 2, image 1 of 2 Razer Blade 15 (2022) Fan and Heatsink Replacement, Remove the laptop back cover: step 2, image 2 of 2
    • Position the laptop as it’s shown in pic 1.
    • Remove 6 torx screws and put them on the magnetic mat
    • Insert an opening pick and slide it around the two shorter sides to unlock the pins
    • Slide the case towards you. The goal is that the 3 inserts on the case slide out (see pic2. Yellow marks)
  3. Razer Blade 15 (2022) Fan and Heatsink Replacement, Disconnect the battery: step 3, image 1 of 1
    • Use a spudger to disconnect the battery. It is the pop up connector with the orange cable
  4. Razer Blade 15 (2022) Fan and Heatsink Replacement, Prep for removing the heatsink: step 4, image 1 of 1
  5. Razer Blade 15 (2022) Fan and Heatsink Replacement, Unfasten the fans: step 5, image 1 of 1
    • There are two Philips screws in each fan. Remove them
    • One is easily visible.
    • The other one is under the black plastic cover (see orange markers)
    • Do this on both fans
    • If you want, you can carefully remove the connection to the motherboard (yellow circle). XetThe tested this and could be removed, (See comment below)
  6. Razer Blade 15 (2022) Fan and Heatsink Replacement, Clean the fan: step 6, image 1 of 3 Razer Blade 15 (2022) Fan and Heatsink Replacement, Clean the fan: step 6, image 2 of 3 Razer Blade 15 (2022) Fan and Heatsink Replacement, Clean the fan: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Use the brush and dust blower to clean the fans
    • You might also use the tweezers to remove debris
  7. Razer Blade 15 (2022) Fan and Heatsink Replacement, Remove the heatsink: step 7, image 1 of 1
    • There are 10 Philips screws with a spring. Unfasten them
    • Now lift the heatsink carefully. The thermal paste offers more resistance than normal.
    • The heatsink is a heavy, copper metal component.
  8. Razer Blade 15 (2022) Fan and Heatsink Replacement, Clean the thermal paste from the CPU and GPU: step 8, image 1 of 2 Razer Blade 15 (2022) Fan and Heatsink Replacement, Clean the thermal paste from the CPU and GPU: step 8, image 2 of 2
    • Use a micro fibre cloth with alcohol to remove the thermal paste on the GPU, CPU and the heatsink
  9. Razer Blade 15 (2022) Fan and Heatsink Replacement, Reapply thermal paste on the GPU and CPU: step 9, image 1 of 1
    • Reapply thermal paste on CPU and GPU. (red squares)
    • Put the heatsink back and fasten it
    • Put the fans back and fasten them
    • Reconnect the display ports and put the tape back
    • Reconnect the battery
    • Close the case
    • And it’s done! Test the working temperature now it should be much lower.
3 other people completed this guide.
Beatriz Pozo Arcos
783 Reputation
4 Guides authored
2 Comments
The internal power connector is soldered on motherboard or connected with cable to motherboard ?
adrianTNT - Reply
It seems to be soldered (see image on step 7) but I would need to reopen the laptop to confirm.
Beatriz Pozo Arcos - Reply
Past 24 Hours: 4
Past 7 Days: 98
Past 30 Days: 415
All Time: 5,259
