Join the Repair Community - Create Account
You're viewing a previously published version of this guide.  View latest version
Older Newer
Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement
Spencer Day
Spencer Day and one other contributor
Last updated on Feb 20, 2025
5 - 10 minutes
Moderate
Introduction
Go to step 1
Use this guide to remove or replace the back cover on your Razer Blade 15 Advanced Model (Early 2020) laptop.
Tools
Show more…
  1. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Unfasten the back cover: step 1, image 1 of 2 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Unfasten the back cover: step 1, image 2 of 2
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  2. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: step 2, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: step 2, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Insert an opening pick: step 2, image 3 of 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  3. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: step 3, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: step 3, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Angle the opening pick: step 3, image 3 of 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  4. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: step 4, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: step 4, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the bottom right corner: step 4, image 3 of 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: step 5, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: step 5, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Free the front edge: step 5, image 3 of 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  6. Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: step 6, image 1 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: step 6, image 2 of 3 Razer Blade 15 Advanced Model (Early 2020) Back Cover Replacement, Remove the back cover: step 6, image 3 of 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
Gear Up For Future Repairs
Shop all
Spencer Day
129,768 Reputation
884 Guides authored
iFixit Member of iFixit
Staff
120 Members
23,090 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 55
All Time: 1,120
