Razer Blade 15" (2018) Battery Disconnection
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Razer Blade 15" (2018) Battery Disconnection, Prepare your laptop for disassembly: step 1, image 1 of 2 Razer Blade 15" (2018) Battery Disconnection, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) Battery Disconnection, Unfasten the back cover: step 2, image 1 of 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) Battery Disconnection, Insert an opening pick: step 3, image 1 of 3 Razer Blade 15" (2018) Battery Disconnection, Insert an opening pick: step 3, image 2 of 3 Razer Blade 15" (2018) Battery Disconnection, Insert an opening pick: step 3, image 3 of 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) Battery Disconnection, Angle the opening pick: step 4, image 1 of 3 Razer Blade 15" (2018) Battery Disconnection, Angle the opening pick: step 4, image 2 of 3 Razer Blade 15" (2018) Battery Disconnection, Angle the opening pick: step 4, image 3 of 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) Battery Disconnection, Free the bottom right corner: step 5, image 1 of 3 Razer Blade 15" (2018) Battery Disconnection, Free the bottom right corner: step 5, image 2 of 3 Razer Blade 15" (2018) Battery Disconnection, Free the bottom right corner: step 5, image 3 of 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Battery Disconnection, Free the front edge: step 6, image 1 of 3 Razer Blade 15" (2018) Battery Disconnection, Free the front edge: step 6, image 2 of 3 Razer Blade 15" (2018) Battery Disconnection, Free the front edge: step 6, image 3 of 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) Battery Disconnection, Remove the back cover: step 7, image 1 of 3 Razer Blade 15" (2018) Battery Disconnection, Remove the back cover: step 7, image 2 of 3 Razer Blade 15" (2018) Battery Disconnection, Remove the back cover: step 7, image 3 of 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) Battery Disconnection, Soften the battery cable tape adhesive: step 8, image 1 of 2 Razer Blade 15" (2018) Battery Disconnection, Soften the battery cable tape adhesive: step 8, image 2 of 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) Battery Disconnection, Peel up the battery cable tape: step 9, image 1 of 3 Razer Blade 15" (2018) Battery Disconnection, Peel up the battery cable tape: step 9, image 2 of 3 Razer Blade 15" (2018) Battery Disconnection, Peel up the battery cable tape: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) Battery Disconnection, Disconnect the battery: step 10, image 1 of 3 Razer Blade 15" (2018) Battery Disconnection, Disconnect the battery: step 10, image 2 of 3 Razer Blade 15" (2018) Battery Disconnection, Disconnect the battery: step 10, image 3 of 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
Clay Eickemeyer
96,729 Reputation
466 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
15,958 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 57
