Razer Blade RZ09-0102 Battery Replacement
Nicole Schukow
Nicole Schukow and 6 other contributors
Last updated on June 28, 2021
15 minutes
Moderate
Introduction
Go to step 1
A guide to remove and replace the battery for the Razer Blade RZ09-0102. You may want to replace your battery if the battery cannot hold a charge or drains after an unreasonably short time. The battery needs to be removed if working on other components as well.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
  1. Razer Blade RZ09-0102 Battery Replacement, Rear Panel: step 1, image 1 of 1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Battery Replacement, Battery: step 2, image 1 of 2 Razer Blade RZ09-0102 Battery Replacement, Battery: step 2, image 2 of 2
    • Remove the seven screws holding the battery in place using a Phillips #0 screwdriver.
  3. Razer Blade RZ09-0102 Battery Replacement: step 3, image 1 of 1
    • Unlock the ZIF connectors securing the right ribbon cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Carefully pull the two ribbon cables out of their sockets.
  4. Razer Blade RZ09-0102 Battery Replacement: step 4, image 1 of 1
    • Use an opening tool to unlock the ZIF connector securing the white ribbon over the battery.
  5. Razer Blade RZ09-0102 Battery Replacement: step 5, image 1 of 2 Razer Blade RZ09-0102 Battery Replacement: step 5, image 2 of 2
    • Carefully pull out the two connectors out of their sockets.
    • Pull parallel to the motherboard, not straight up.
  6. Razer Blade RZ09-0102 Battery Replacement: step 6, image 1 of 2 Razer Blade RZ09-0102 Battery Replacement: step 6, image 2 of 2
    • Pull the wide battery connector towards the battery to disconnect it from the motherboard.
  7. Razer Blade RZ09-0102 Battery Replacement: step 7, image 1 of 2 Razer Blade RZ09-0102 Battery Replacement: step 7, image 2 of 2
    • Remove the battery from the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
6 other people completed this guide.
2 Comments
Hey Nicole, thank you for writing this fantastic guide. Do you have any recommendations for vendors or websites for this specific battery replacement?
Erfan Moradi - Reply
My dudes, anyone can tell me what model is the RZ09-0102 battery connector and where to order the motherboard side?
A friends laptop got the connector melted *moisture* and I can’t identify this dense 30-pin oedipus.
Giorgi Kikuashvili - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 50
All Time: 26,423
