Razer Blade RZ09-0102 Fan Replacement
  1. Razer Blade RZ09-0102 Fan Replacement, Rear Panel: step 1, image 1 of 1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Fan Replacement, Fan: step 2, image 1 of 1
    • Remove the three black rubber pads that cover the screws holding the fan.
  3. Razer Blade RZ09-0102 Fan Replacement: step 3, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the three 1/4 inch screws.
  4. Razer Blade RZ09-0102 Fan Replacement: step 4, image 1 of 1
    • Disconnect the wire that goes from the fan into the white connector, but leave the wire attached to the fan.
  5. Razer Blade RZ09-0102 Fan Replacement: step 5, image 1 of 2 Razer Blade RZ09-0102 Fan Replacement: step 5, image 2 of 2
    • Lift the fan out with your hands.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 6,604
