Razer Blade RZ09-0102 Heat Pipe Replacement
  1. Razer Blade RZ09-0102 Heat Pipe Replacement, Rear Panel: step 1, image 1 of 1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Heat Pipe Replacement, Heat Pipes: step 2, image 1 of 2 Razer Blade RZ09-0102 Heat Pipe Replacement, Heat Pipes: step 2, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the six 8 mm screws holding the cooling rod to the motherboard .
  3. Razer Blade RZ09-0102 Heat Pipe Replacement: step 3, image 1 of 1
    • Lift the cooling rod straight up and out of the laptop.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,399
