Razer Blade RZ09-0130 2015 Battery Replacement
  1. Razer Blade RZ09-0130 2015 Battery Replacement, Back Panel: step 1, image 1 of 2 Razer Blade RZ09-0130 2015 Battery Replacement, Back Panel: step 1, image 2 of 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Battery Replacement: step 2, image 1 of 2 Razer Blade RZ09-0130 2015 Battery Replacement: step 2, image 2 of 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Battery Replacement, Battery: step 3, image 1 of 1
    • Detach the battery's ribbon cable from the motherboard.
  4. Razer Blade RZ09-0130 2015 Battery Replacement: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the six 3 mm screws securing the battery.
    • Lift the battery up and out.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,013
