Razer Blade RZ09-0130 2015 Fan Replacement
  1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: step 1, image 1 of 2 Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: step 1, image 2 of 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Fan Replacement: step 2, image 1 of 2 Razer Blade RZ09-0130 2015 Fan Replacement: step 2, image 2 of 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: step 3, image 1 of 2 Razer Blade RZ09-0130 2015 Fan Replacement, Fan: step 3, image 2 of 2
    • Remove the three screw caps by pulling them upward with your fingers.
  4. Razer Blade RZ09-0130 2015 Fan Replacement: step 4, image 1 of 1
    • Remove the three 3mm Phillips #0 screws.
  5. Razer Blade RZ09-0130 2015 Fan Replacement: step 5, image 1 of 2 Razer Blade RZ09-0130 2015 Fan Replacement: step 5, image 2 of 2
    • Peel back the two adhesive strips from the fan until they are removed.
  6. Razer Blade RZ09-0130 2015 Fan Replacement: step 6, image 1 of 3 Razer Blade RZ09-0130 2015 Fan Replacement: step 6, image 2 of 3 Razer Blade RZ09-0130 2015 Fan Replacement: step 6, image 3 of 3
    • Remove the connector by pulling it away from the motherboard with your fingers.
  7. Razer Blade RZ09-0130 2015 Fan Replacement: step 7, image 1 of 1
    • Holding the rounded edge of the fan, slowly lift upwards until it is removed.
  8. Razer Blade RZ09-0130 2015 Fan Replacement: step 8, image 1 of 1
    • Repeat the preceding steps to remove the second fan.
Tyler Clayton
183 Reputation
1 Guide authored
Cal Poly, Team S18-G1, White Winter 2020 Member of Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 640
