Razer Blade RZ09-0130 2015 Speaker Replacement
  1. Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: step 1, image 1 of 2 Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: step 1, image 2 of 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Speaker Replacement: step 2, image 1 of 2 Razer Blade RZ09-0130 2015 Speaker Replacement: step 2, image 2 of 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
  4. Razer Blade RZ09-0130 2015 Speaker Replacement: step 4, image 1 of 2 Razer Blade RZ09-0130 2015 Speaker Replacement: step 4, image 2 of 2
    • Using your fingers, gently pull on the wire connecting the speaker to the motherboard until it disconnects.
  5. Razer Blade RZ09-0130 2015 Speaker Replacement: step 5, image 1 of 1
    • Pick up and remove the speaker.
  6. Razer Blade RZ09-0130 2015 Speaker Replacement: step 6, image 1 of 1
    • Repeat the preceding steps to remove the second speaker.
Carson Kellerman
495 Reputation
4 Guides authored
Cal Poly, Team S18-G1, White Winter 2020 Member of Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 361
