Razer Blade RZ09-0130 2015 Trackpad Button Replacement
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: step 1, image 1 of 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: step 1, image 2 of 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: step 2, image 1 of 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: step 2, image 2 of 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: step 3, image 1 of 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: step 3, image 2 of 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: step 3, image 3 of 3
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: step 4, image 1 of 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: step 4, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: step 5, image 1 of 1
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
Carson Kellerman
495 Reputation
4 Guides authored
Cal Poly, Team S18-G1, White Winter 2020 Member of Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Members
6 Guides authored
One Comment
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 2,203
