Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement
  1. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Back Panel: step 1, image 1 of 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Back Panel: step 1, image 2 of 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: step 2, image 1 of 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: step 2, image 2 of 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 2 of 2
    • Flip up the black plastic lock-bar on the ZIF connector, then gently pull the ribbon cable directly out of its motherboard port.
  4. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: step 4, image 1 of 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: step 4, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the single 3 mm screw from the upper-right corner of the Wi-Fi card.
  5. Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: step 5, image 1 of 2 Razer Blade RZ09-0130 2015 Wi-Fi Card Replacement: step 5, image 2 of 2
    • Slide an ESD-safe tool under the black and gray coaxial cable connections, and gently lift the plugs vertically to disconnect them from the Wi-Fi card.
    • Grip the Wi-Fi card from both sides and pull it directly out of its port.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 379
