Razer Blade Stealth 2016 Hard Drive Replacement
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: step 2, image 1 of 1
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: step 3, image 1 of 1
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: step 4, image 1 of 1
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: step 5, image 1 of 2 Razer Blade Stealth 2016 Hard Drive Replacement: step 5, image 2 of 2
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: step 6, image 1 of 2 Razer Blade Stealth 2016 Hard Drive Replacement: step 6, image 2 of 2
    • Carefully slide the hard drive out from its slot.
Lindsay Grant
403 Reputation
3 Guides authored
USF Tampa, Team S1-G4, Leahy Fall 2019 Member of USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 45
All Time: 2,799
