Razer Blade Stealth 2016 RAM Replacement
  1. Razer Blade Stealth 2016 RAM Replacement, Battery: step 1, image 1 of 3 Razer Blade Stealth 2016 RAM Replacement, Battery: step 1, image 2 of 3 Razer Blade Stealth 2016 RAM Replacement, Battery: step 1, image 3 of 3
    • Use a Torx (T5) screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 RAM Replacement: step 2, image 1 of 2 Razer Blade Stealth 2016 RAM Replacement: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 RAM Replacement: step 3, image 1 of 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 RAM Replacement, RAM: step 4, image 1 of 1
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 RAM Replacement: step 5, image 1 of 1
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heat sink.
  6. Razer Blade Stealth 2016 RAM Replacement: step 6, image 1 of 1
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 RAM Replacement: step 7, image 1 of 2 Razer Blade Stealth 2016 RAM Replacement: step 7, image 2 of 2
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 RAM Replacement: step 8, image 1 of 1
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 RAM Replacement: step 9, image 1 of 1
    • Desolder the pins on the motherboard to remove the RAM.
    • WARNING: Be careful while using the soldering iron.
2 Guide Comments
fanboy bowing down
Hal - Reply Share
Does anyone know what RAM modules I could use to replace the 8gb my 2016 stealth has? It still runs flawlessly but I'd like to have at least 16gb if possible.
Mike D - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,644
