Razer Blade Stealth 2017 Fan Replacement
  1. Razer Blade Stealth 2017 Fan Replacement, Battery: step 1, image 1 of 2 Razer Blade Stealth 2017 Fan Replacement, Battery: step 1, image 2 of 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Fan Replacement: step 2, image 1 of 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Fan Replacement: step 3, image 1 of 2 Razer Blade Stealth 2017 Fan Replacement: step 3, image 2 of 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Fan Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Fan Replacement: step 5, image 1 of 2 Razer Blade Stealth 2017 Fan Replacement: step 5, image 2 of 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Fan Replacement, Fan: step 6, image 1 of 2 Razer Blade Stealth 2017 Fan Replacement, Fan: step 6, image 2 of 2
    • Use a plastic spudger to lift the white clasp on the fan connector.
  7. Razer Blade Stealth 2017 Fan Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to pull the fan cable out of the opened connector terminal.
  8. Razer Blade Stealth 2017 Fan Replacement: step 8, image 1 of 3 Razer Blade Stealth 2017 Fan Replacement: step 8, image 2 of 3 Razer Blade Stealth 2017 Fan Replacement: step 8, image 3 of 3
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  9. Razer Blade Stealth 2017 Fan Replacement: step 9, image 1 of 3 Razer Blade Stealth 2017 Fan Replacement: step 9, image 2 of 3 Razer Blade Stealth 2017 Fan Replacement: step 9, image 3 of 3
    • Remove any tape attached to the fans.
    • Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
  10. Razer Blade Stealth 2017 Fan Replacement: step 10, image 1 of 2 Razer Blade Stealth 2017 Fan Replacement: step 10, image 2 of 2
    • Use a plastic spudger to slide the fans out of the case.
2 other people completed this guide.
Helene Willits
765 Reputation
6 Guides authored
Cal Poly, Team S11-G3, Regan Fall 2019 Member of Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Members
7 Guides authored
One Comment
What is the part number for the black fan? I'm trying to buy a replacement but I can't find any :(
Sang Jae Kouwenberg - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 32
All Time: 2,265
